a sign a fuel filter has gone bad
Old Jan 17, 2010 | 07:20 AM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
this might come in handy in solving a future or current problem for somebody
When I bought my car last month, I could drive it for 10-15 minutes just fine, but the longer I drove it, the worse it got. The check engine light would begin to flicker randomly, and the permormance would bog down almost exactly with the flicker. No codes were saved in the ECM
I read in my shop manual that this could be a problem with the ECM, or it could be a clogged fuel filter. well duh, I bought a fuel filter from NAPA and went to work. Despite the car has 176K miles on it, there was a delco filter installed. Cartainly that couldn't be the orginal filter, could it?
In any case, it's in the trash now, and I haven't seen a single check engine light flicker since then.
Old Jan 17, 2010 | 05:47 PM
docpnutbutr's Avatar
Car: 87 Z-28, 89 GTA, 79 WS-6,
Engine: 87- 305 TPI, 335 stroker, 403 Olds.
Transmission: 700r4,700r4, and th400
Axle/Gears: mostly stock
Re: a sign a fuel filter has gone bad
This might be the source of the problem I'm having. Gonna give it a whirl. Wish me luck.
Old Jan 17, 2010 | 06:17 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
In my experience, when the filter starts to get plugged the engine experiences longer than normal crank times (TPI).
Old Jan 17, 2010 | 07:32 PM
58mark's Avatar
good luck! Hope that helps
Old Jun 8, 2011 | 03:14 AM
jeff_blake's Avatar
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
yep, mine needs replacement, been putting it off.
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
Winchester1094
Aug 18, 2015 10:23 AM
92camaroJoe
Aug 13, 2015 06:07 AM
