1982 camaro. need opinions!!
Old Jan 19, 2010 | 11:19 PM
DPALz28's Avatar
Car: 1982 CAMARO
Transmission: 3 SPD AUTO
well i bought a camaro last week and just got it out the shop yesterday. and when i first left it was riding real good. (350 engine automatic.) my mechanic said i need to drive the car and run the gas out because it sat for years and the gas rotted out. when i take off the car drives good unless i try to take off all the way. but when i get up in speed the car starts to jerk and causes the speed to drop and when i take my foot off the gas it stops and i can go for a lil bit but then it starts to jerk again. is that the bad gas thats making it do that or is it something else?? any knowledge helps. thanks
Old Jan 19, 2010 | 11:23 PM
osso12's Avatar
Car: 85 Z28 Vert
Engine: LG4 ENGINE 5.0 4BBL
Transmission: 700R 4SPD
Axle/Gears: 3:08
Re: 1982 camaro. need opinions!!
Fuel Injected or Carb, TBI?
Original engine or NOM?
Its been awhile but I have had 2 IROC z's, a Z28 and a 4 cyl coupe, and a 82 berlenetta,
All were 305 CI except the 4 cyl coupe
and for the life of me I don't recall any stock 82 having a 350 in it from the factory.
If you know for sure the gas is bad in the tank, why not drain the tank and install fresh fuel filters for starters?
Old Jan 19, 2010 | 11:28 PM
DPALz28's Avatar
Car: 1982 CAMARO
because on the 82s the gas tank is all the way in the middle and you would have to drop the entire exhaust to drain it. so he said to drive it til it runs out. and im actually not sure if its tbi or what not. i know i had to rebuild the carb when it was in the shop. hopefully that helps... im just now joining the camaro life. ive got lots to learn!!
Old Jan 19, 2010 | 11:31 PM
osso12's Avatar
Car: 85 Z28 Vert
Axle/Gears: 3:08
No problem there. We all have lots to learn including me but you can buy a manual syphon pump at any auto parts store.
Why take a chance and clog up the fuel system including rebuilding the carb a second time with whats left in the tank by continuing to drive it that way?
DPALz28's Avatar
Car: 1982 CAMARO
well maybe it is a 305. the guy told me it was a 350 but who knows??! is there any easy way to tell by looking??
Old Jan 19, 2010 | 11:33 PM
DPALz28's Avatar
Car: 1982 CAMARO
i tried to syph it out but the hose wouldnt go all the way through. its like it has a screen on it?? but do you think the gas is making the car run that way??
Old Jan 19, 2010 | 11:34 PM
osso12's Avatar
Car: 85 Z28 Vert
Axle/Gears: 3:08
Pop your vin into here its free. It will tell you what the car was born with from the factory or should anyway.
http://www.dmv.org/used-car-history-report.php?
Click on the free report you don't have to pay anything.
Old Jan 19, 2010 | 11:35 PM
osso12's Avatar
Car: 85 Z28 Vert
Axle/Gears: 3:08
Im wanting to side with the mechanic but I don't agree with continue to driving it that way. What are your plans once the tank is empty?
Old Jan 19, 2010 | 11:37 PM
DPALz28's Avatar
Car: 1982 CAMARO
ima take my time and fix it up. thinking about putting flowmaster on
Old Jan 19, 2010 | 11:42 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Best way to tell what motor you have is to look at the casting numbers, it's going to be hard to see with the motor in the car but it is possible to see them. They are on the driver's side of the block, where the motor bolts to the trans.
I'd drop the tank and drain it rather then risk clogging.
Old Jan 19, 2010 | 11:49 PM
DPALz28's Avatar
Car: 1982 CAMARO
yea. i think im gona get the pump you told me about... i have one more question but its about the headlights. all of my lights work on the car except my headlights. but when i first turned them on when i got it out the shop they were working but now they dont. do u think thats the fuse or a shortage??
Old Jan 23, 2010 | 09:58 PM
ymenic's Avatar
Car: 1982 Camaro z-28
Engine: 307
Transmission: th-350 with stage 2 shift kit
Axle/Gears: stock
Yeah, if it stock it will be a 305, I have a 1982 Z-28 with a 305 but a 4 speed manual.
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
rusty vango
Sep 29, 2015 02:44 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
indygene
Sep 26, 2015 11:21 AM
