chirping noise/odd SES light occurances
Old Jan 20, 2010 | 01:12 AM
mascarpone's Avatar
Hello I own an '87 firebird with the 2.8L that has been completely rebuilt. However for the past month or so it makes a really annoying squeaking sound that seems like its coming from the alternator. I started noticing it after driving in the rain puddles would splash up and it would squeak really loud for a couple of seconds and my interior lights would dim while it was squeaking; now its just a constant chirping sound that I can't figure out.
Also I just finished the rebuild of the motor with the new egr valve and after installing it my SES light comes on at odd times like after driving through residential areas going 25 for an extended period of time or sometimes on the highway but not as often.. any help would be greatly appreciated!
Joe
Old Jan 20, 2010 | 02:19 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
The Car Doctor Will See You Now
You can use a funnel and rubber tubing as a stethoscope.
Make sure you stay away from moving parts.
That will help locate the source of the chirping.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime, and the nitwits that need headlights for a little rain
Old Jan 20, 2010 | 10:28 PM
MightyMouse's Avatar
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
Re: The Car Doctor Will See You Now
Belts? Spritz them with WD-40 and see if the sound stops.
Old Jan 21, 2010 | 04:47 PM
mascarpone's Avatar
So I noticed the serpentine belt was really lose fitting but I had disreguarded it before because i changed the tensioner and belt before. i ended up getting a belt that was 1 1/2" smaller than the one that was on there and it seems to have cleared up all of the chirping sounds for now.
Theres still the question of the SES light coming on. after sitting at idol for an extended period of time it comes on once i accelerate up to 25mph or so and it also does it after i've been driving at slow speeds for an extended period of time. The light goes off if i turn the car off and start it again but its frustrating me that it comes on to begin with. the only thing i can relate it to is recently changing the EGR valve. im stumped
Old Jan 21, 2010 | 08:29 PM
Goany's Avatar
may bea simple o2 sensor? get it scanned and get the code number. most shops will scan ur car for free
Old Jan 21, 2010 | 09:07 PM
mascarpone's Avatar
its new, everything is new. the light wasnt coming on at all until after i changed the egr valve.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TBRays98
Sep 6, 2015 05:05 PM
Jetmeck
Sep 4, 2015 12:29 AM
luvofjah
Sep 3, 2015 07:08 PM
andy74
Sep 3, 2015 08:41 AM
