hesitation need help please
Old Jan 24, 2010 | 04:27 PM
DPALz28's Avatar
Car: 1982 CAMARO
Transmission: 3 SPD AUTO
just bought a 1982 camaro sport with a v8 305 in it and got it out the shop on thursday. (needed a new carb but just rebuilt it instead) my mechanic said the fuel in it is horrible and needs to be run out. ( he said i should drive until on empty because tank was hard to drop w/o dropping exhaust, but i decided to siphon it out.) after i siphoned it out i bought some Gumout fuel cleaner and filled it up with 91. ran good for about an hour then started to to hesitate when driving and taking off from stop.( would even die on me and would start back up sometimes but sometimes it would take 5-10 minutes.) changed fuel filter and ran good for about an hour again and started to do the same. changed the fuel filter again because it was dirty and ran really good but only for about 30 minutes. do you think i should just keep changing the filter (mechanics idea until fuel is clean) or do you think there is something else wrong??
i was trying to check the codes and see if it was something else but have no clue how to do it correctly. I really need help!! i have lots to learn so please give your opinion. thanks in advance.
Old Jan 24, 2010 | 04:45 PM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
Re: hesitation need help please
What I would do, is empty the tank. Fill it up a little. Than run the fuel pump with the filter off into a bucket NOT TO THE ENGINE. Keep doing this until you think necessary. There for you don't need to keep going through filters.
Old Jan 24, 2010 | 07:38 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Keep changing filters?
Old Jan 24, 2010 | 07:58 PM
Blind Driver's Avatar
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
How will he do that with a mechanical pump?
Change the fuel filter again and add a clear fuel filter in between the rubber fuel lines so you can tell when it's getting dirty.
Old Jan 24, 2010 | 08:56 PM
JTNKTZ's Avatar
Engine: 355/350
Oh missed the '82' part haha.
Old Jan 25, 2010 | 04:27 PM
DPALz28's Avatar
Car: 1982 CAMARO
yea i was thinking about doing exactly what u said but the one i bought isnt clear it just silver, but i wish i would have gotten a clear one.
but thanks, ima give it a shot.
Old Jan 25, 2010 | 04:28 PM
Car: 1986 Trans Am
Engine: 5.0
Buy spares
Old Jan 26, 2010 | 02:20 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I had the same problem. Changed the fuel pump and problem solved. Yours is in the begining stages of going bad.
Old Jan 28, 2010 | 03:32 PM
my88iroc350's Avatar
I did this same thing it ran great for 2 or 3 days then it started doin the same thing all over again
Fanatic1074
Oct 3, 2022 05:57 AM
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
