self aligning roller rocker question.
Old Jan 28, 2010 | 09:53 PM
88formula305tpi's Avatar
Car: 1988 Firebird Formula WS6
Engine: 305 tpi lb9
Transmission: 5 speed
Axle/Gears: 3.45
Ok this may be stupid question. I am looking at comp cam 1.6 roller tip rocker that have the ball pivot since I think they will fit the best under centerbolt vc. PN is 1418-16.
I know the description says self aligning like I need but looking at the picture shows no grooves in the roller so how do they self align? I am guessing it is very slight and not noticable in pic?
I know that other full roller rockers have the groove.
Old Jan 28, 2010 | 10:18 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: self aligning roller rocker question.
should have two little tangs/disc on outside of roller to keep on the valve stem. Might be wrong pic. on there too
Old Jan 28, 2010 | 10:57 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Old Jan 28, 2010 | 11:14 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
You can fit Comp's "Pro Magnum" rockers under a stock perimiter-bolt valve cover (maybe centerbolt too, no experience there) if you just use the thick cork gaskets. I did it and they cleared just fine. The ProMags need the 1/4" longer ARP studs to get the poly-locks to engage deep enough, but it still clears just fine. And thats a rediculously tough set of rockers.
Old Jan 29, 2010 | 01:41 PM
Engine: 305 tpi lb9
Axle/Gears: 3.45
thanks for the pic, now I understand how they self align. my heads are at the shop right now. I wish I would have known they require longer studs but are you sure we are talkin about the same rocker? the pic you show looks like a full roller and the ones I have are a ball pivot with long slot.
Old Jan 29, 2010 | 01:44 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
The stock rocker studs work just fine with those rockers.
Old Jan 29, 2010 | 01:47 PM
Engine: 305 tpi lb9
Axle/Gears: 3.45
i see you have the 1.52's, did they fit under the valve covers ok?
Old Jan 29, 2010 | 02:20 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Make sure you need self-aligning rockers. Might not be an issue with your '88, but my '87 has centerbolt valve covers and it doesn't have self-aligning rockers.
Old Jan 29, 2010 | 05:24 PM
mnorton's Avatar
Engine: 305 LB9 TPI
They fit under the valve covers just fine. I had installed them on the stock heads before I bought the World heads and they were just fine on them as well.
Old Jan 29, 2010 | 06:24 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
The fulcrum on the full rollers is thicker than the stock type pivot ball meaning there is not enough thread left on stock studs for posilock engagement
Was just an example to show how SA rockers align on valve stem
Old Jan 31, 2010 | 10:25 PM
Air_Adam's Avatar
Those are the Comp 'Magnum' rockers, not the 'Pro Magnum' rockers. The ones you have in that pic do not require longer studs. They will be just fine with stock studs.
These are the 'Pro Magnum' rockers... the BIG bearing in the middle is the reason for needing the longer studs:
skinny z
Oct 5, 2015 06:23 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Agent507943
Camaros Wanted
Oct 2, 2015 07:17 AM
92projectcamaro
Sep 29, 2015 07:07 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
