Gas Leak. Need Help!!
Old Jan 29, 2010 | 11:57 AM
Miles87Z28's Avatar
Car: 05 Pontiac Sunfire, 87 Z28
Engine: 2.2 Ecotec, 350 TPI
Transmission: Auto, 700r4 with shift kit
Axle/Gears: No clue, limited slip.
Motor: 350 TPI
I have a gas leak right over the rear axle, almost positive its coming from the top of the tank. Heres the questions are the fuel lines solid metal all the way to the fuel pump or do they have rubber lines connecting them to the pump/sending unit?? I don't want to drop the tank but if i got to i guess i can, but can i do it without dropping the rear as i would be doing this by myself without a lift and i've never done this before?? Any help would be great guys.
Old Jan 29, 2010 | 12:08 PM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Re: Gas Leak. Need Help!!
From the fittings up they're solid metal tubes into the tank.
The more parts that you remove to make more room, the easier its going to be to get the tank out.
Old Jan 30, 2010 | 02:25 PM
Mike1's Avatar
I have the same problem. Have you pulled your tank yet? Mine seems to be leaking while the car just sits. It does seem to be coming from the top. Would this just be the lines, or something else?
Old Jan 30, 2010 | 02:31 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Check your fuel tank filler neck. They can become loose and are a potential source of leaks.
Old Jan 30, 2010 | 03:44 PM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
GM even had a recall for this....!!
Old Jan 30, 2010 | 04:16 PM
Drew's Avatar
GM did have a recall, but it didn't apply to 1987. Chances are if the filler neck is leaking, it's from age, vibration, being damaged in a fuel pump change, etc. There are a bunch of lines and potential places were the fuel could be leaking. I'd start by inspecting the filler neck, and then consider dropping the tank.
Old Jan 31, 2010 | 01:28 AM
Not age, but bad design causes the filler neck to leak. Pinholes at the base, around the welding.
Even cars 5-6 years old suffered leaking filler necks back in the nineties.....I know, mine did, but GM refused to cure it, because my car was privately imported into the Netherlands.....they wanted me to go to a US dealer....!!
I fixed it with "liquid" metal around the filler neck.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
86maro_252
Oct 10, 2015 06:52 PM
kx3g
Sep 28, 2015 08:14 AM
reactor60
Sep 22, 2015 01:44 PM
rjcme
Sep 5, 2015 01:23 PM
