Summit Aluminum Oil Pan
Old Feb 4, 2010 | 03:38 AM
P-ROC's Avatar
Car: 86 IROC-Z28
Engine: LB9
My oil pan was leaking and when I was cleaning the surfaces to put on a new gasket I noticed that it wasn't true so I ordered a Summit Cast Aluminum Oil Pan and received it today. It came with the front gasket where the pan meets the timing cover and a note that said to use the thin front gaskets on it. Does anyone know if my chrome timing chain cover will mate up properly for a good seal? Also, I already purchased the FelPro performance gasket before the oil pan, will this work on the aluminum pan?
Old Feb 4, 2010 | 05:03 AM
Twin_Turbo's Avatar
Re: Summit Aluminum Oil Pan
If you have the thick gasket the pan may crack. Use what you're supposed to be using.
Old Feb 5, 2010 | 10:52 PM
P-ROC's Avatar
Car: 86 IROC-Z28
Engine: LB9
What about the timing cover? Do I need to change that or will it be fine?
Old Feb 5, 2010 | 11:04 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The timing cover should fit fine, and will seal as well as anything chromed ever does.
Old Feb 8, 2010 | 08:12 PM
P-ROC's Avatar
Car: 86 IROC-Z28
Engine: LB9
Just to end this thread. I went to use the recommended gasket and bought the others that it said to use. The quality of the summit oil pan was so bad I am sending it back and have to get another one. The gaskets didn't fit correctly. The back rubber gasket was smaller than the cut out on the pan. There was metal on the gasket surface that hadn't been smoothed out. DON'T BUY ONE!
Old May 10, 2010 | 03:08 PM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
I have to second not buying a summit pan. I had the OEM style replacement 4qt that was just prettier and time wise cheaper than cleaning up the stock pan. Worked good until I had to pull it to fix a leak I caused in the timing cover/oil pan snout area, now it leaks profusely- even with a one piece gasket. POS.
I did get 2 good years out of it though, but just be warned it's a 1 time use pan. I'm going with a Canton when I lift her up again to replace the pan.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
my86bird
Oct 23, 2015 12:20 PM
New2Chevy
Sep 28, 2015 12:35 AM
89-S-dime
Southern California Area
Sep 4, 2015 10:34 AM
Navy8125
Aug 21, 2015 09:32 AM
