zz4 heads? on 350 tpi block? help
Car: 1987 Firebird GTA
Engine: 350 SBC
Transmission: 700r
I have a 1987 350 gta tpi n I was wondering if I can slap the zz4 heads on the tpi block running the stock tpi setup if so what would I have to do or change
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: zz4 heads? on 350 tpi block? help
bolt them on bro! the only problem i know of is bolt holes in the center of the intake need to be elongated a bit since the holes on the alum heads are the same as 86 and older heads whereas your intake is for the 87 and newer style not a big deal..... perfect time for a Stealthram
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
They are the same heads the L98 Corvettes used in the late '80s/90s.
Engine: 350 SBC
Transmission: 700r
Already!!!!!!!! Sounds great thanks......
Well I was wondering will the ecm have to be chipped or messed with?
And are self adjusting rollers rockers a good idea for this head
Car: '88 Trans Am
Engine: 5.7L TPI
A performance chip or a custom tune will enhance the swap but having a MAF equipped car helps a bunch...
Transmission: 4L80E/4L80E
Sanjay
Aug 12, 2015 03:41 PM
