Car will start with Fluid and Stay Running
Old Feb 9, 2010 | 04:29 PM
merdenomsx12's Avatar
Hello, Thanks in advance for your help.
92 Pontiac Firebird Formula 5.0 with a 305.
Every once in a while (once a day), my car will turn over but wont fire. I have to use starting fluid to get it running and then it will stay running. Once the car is running, if it idles below 500 rpm it will die, so i upped the idle so it wont hit 500.
I replaced the fuel filter for the heck of it, because i had a brand new one i never used. I also replaced the battery. To me, everything points to an ignition issue, but i wanted the experts opinion on it.
Also, im not sure if this is a coincidence, but the same time this started up, my radiator cooling fan doesnt come on. It will run with the AC on. Im pretty sure is the cooling fan relay but its just weird this happened at the same time as my other problem.
Any ideas?
Old Feb 9, 2010 | 04:55 PM
Twin_Turbo's Avatar
Re: Car will start with Fluid and Stay Running
FP relay
Old Feb 9, 2010 | 07:40 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Any ideas?
I would check the CTS - coolant temp sensor with an ohmmeter, and also datalog to double-check what the ECM is seeing.
Ghettobird52
Jul 5, 2024 11:18 PM
Wade787b
Sep 29, 2015 01:15 PM
kyleb24
Aug 15, 2015 08:24 AM
killer777
Aug 8, 2015 02:47 PM
Sherpajames
Aug 7, 2015 06:56 PM
