Aluminum head weight savings..
Old Feb 9, 2010 | 10:08 PM
1970 Buick's Avatar
Car: 1989 GTA
HI, I am going to put afr aluminum 195 1040'son my l98. Just curious if anyone has info on the weight difference between stock heads and aluminum replacemets. Thanks
Old Feb 9, 2010 | 10:12 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: Aluminum head weight savings..
AFRs are heavy for aluminum heads, but you'll still save right at or just shy of 40 lbs if that's all you change.
Old Feb 9, 2010 | 10:16 PM
1970 Buick's Avatar
Car: 1989 GTA
What do you think adding an aluminum radiator and valve covers(I know it is minimal) would save?
Old Feb 9, 2010 | 10:31 PM
Guest
Guest
Posts: n/a
The stock radiator was already aluminum, with plastic caps. Its very light. The valve covers you may gain weight, the stock ones are thin sheetmetal and dont weigh much.
Old Feb 10, 2010 | 05:46 AM
danziger's Avatar
Car: 1991 Formula Firebird
Engine: L98 with headers/exhaust
Axle/Gears: 3.23 10-bolt
I agree with the 40lb reduction estimate. Headers will knock off a few pounds as well...
Old Feb 10, 2010 | 07:52 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
An aluminum water pump is also a good weight saver.
RBob.
midge54
Dec 27, 2019 04:14 PM
bdads
Aug 24, 2015 06:01 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
