Cam suggestions.
Old Feb 10, 2010 | 05:26 PM
ninety1z's Avatar
Car: '91 Z28
Engine: 5.7
Cam suggestions.
I have a '91 Z28 with a .40 over L98, Trickflow G2 heads, 1.5 roller rockers, Stealthram, 24 lbs. injectors, and a PCM for less chip. I have 2.73's now but plan on 3.73's as soon as the motor is back together. Converter is stock 700R4. I imagine compression would be around 9.5-10 with the 67cc chambers. Trick flow recommends nothing over 236 @ .50, .490", and a 110 LSA because of piston to valve clearance with the turned chambers. I have been waiting for a cam recommendation from Comp since saturday. So I was wondering if anyone has any suggestions. I was think of using a Comp 264, 210 intake at .50, .220 exhaust, .480 on both sides and 112 LSA. Any ideas?
Old Feb 10, 2010 | 05:31 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: Cam suggestions.
I am a true fan of Lingenfelter so my vote is
http://www.lingenfelter.com/mm5/merc...egory_Code=C30
i had very good luck with it in my TPI cars, we also used the old SLP 495/510 with the G2 heads
Old Feb 12, 2010 | 07:49 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
any cam that promises a smooth idle and good vacuum should work for fuel injection with minimum tuning. a roller is the way to go.
Old Feb 12, 2010 | 08:28 PM
85projectZ28's Avatar
Car: 1985 Camaro Z28
Engine: 5.7 LSX
Transmission: Performabuilt 4L60E
Axle/Gears: Strange 12-bolt 3.73
go to comp's website and download camquest for free. enter all your specs and it will give you like ten or so recommended cams. even if you dont go with a comp cam, it gives the numbers for each cam so you can choose one somewhere else and know what LSA, duration and such that you want.
Old Feb 13, 2010 | 09:57 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
I like this LPE cam:
You wouldn't have to change your rear gear with this one.
Old Feb 13, 2010 | 10:35 AM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
I suggest searching the boards for existing engine combo's that are similar to yours, like, for example, mine.
Bill
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
