89 camaro 350 tpi in 74 blazer. wont start
Old Feb 10, 2010 | 05:34 PM
74prerock's Avatar
Put a 89 camaro tpi mtr in my blazer. Keep in mind most of wiring is custom. Starter is wired through button, have vats bypass on it. Have spark, but cant get injectors to pulse. Put noid on injectors can get them to fire if i put 12 volts to dist ref. wire b5 ppl/wht. Changed ignition controll module in dist. I'm stumped bought ready to put a bullet in it.
Old Feb 10, 2010 | 07:57 PM
tpi90rs's Avatar
Car: 87 Formula 350
Engine: 350tpi
Transmission: TH700R4
Axle/Gears: 3.23 limited
Re: 89 camaro 350 tpi in 74 blazer. wont start
well you didn't give us much information. tell us how you wired everything in? you just said if you put voltage to the distributor reference you get the injectors to fire, so, you hooked up the ignition wrong?
Old Feb 10, 2010 | 08:12 PM
74prerock's Avatar
Factory harness less the egr, purge can, port air.. My fuel relay and ignition relay wired of toggle on dash. Put 12 v signal from fuel relay to ecm for fuel signal. Checked all my injectors all 16.1-16.2 ohms. Voltage at all ecm terminal pins where should be. Check my ecm only code is a 12. I'm running msd 6 offroad ignition and msd blaster coil. Never had the stock coil. Notice in schmatics stock coil has some additional wires to it. Do i need to jump pick signal to the dist reference?
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Wade787b
Sep 29, 2015 01:15 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
