still surging
Old Feb 11, 2010 | 05:54 PM
Ryan33R's Avatar
still surging
ok so ive got a 91 tpi 350 ive cleaned the injectors and changed the plugs/wires it hasnt actually died on me "yet"but its getting worse.it runs just fine while driving but when i get to a light or put it in park the rpm goes high then real low and almost dies over and over.it never usually happens when the engine is cool but as soon as it gets a little warm...how can i fix this?
Old Feb 12, 2010 | 08:04 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: still surging
check the codes. if the coolant temp sensor is bad or open circuit it can cause that.
Old Feb 12, 2010 | 09:38 PM
Ryan33R's Avatar
Re: still surging
ok will do,thanks
Old Feb 13, 2010 | 07:12 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: still surging
Check the IAC. The spring may be full of carbon and need cleaning/replaced.
Old Feb 13, 2010 | 07:45 AM
lopezisgod's Avatar
Car: 86 iroc-z, 78 z28, 91 z28
Engine: 355-carb, 350-carb, 350-TPI
Transmission: 5speed, at, 5 speed
Axle/Gears: 3.42, 3.42-stock, 3.42-1LE
Re: still surging
have you done any work on this car before? cam tune . etc?
that can be a big deal in this.. i bought a car and have no clue what the guy did and i have that issue..... we data logged.. noticed the injectors in the car are bigger then stock.. its got 4 350 injectors and 5 305 on a 305 car..also the guy put a 350 pump in the car as well.... he said it was cammed and now were trial and error..we did the coolent temp sensor.. and other stuff and no prevail.. ill watch this thread and post if we come up with anyting.. (next on the list was the iac.....)
Old Feb 15, 2010 | 05:37 PM
Ryan33R's Avatar
Re: still surging
tried the cts and although it definetly needed changing anyways it made no difference but somethin else i just found out is my fans arent working so thats always good lol i think im gonna drop it off at the shop and just get charged alot of money for probably nothing haha
92camaro350cci
Oct 14, 2015 09:29 AM
IROCThe5.7L
Sep 17, 2015 07:48 AM
banksGTA
Sep 13, 2015 11:56 AM
bamaboy0323
Sep 3, 2015 06:07 AM
jbd1969
Aug 17, 2015 07:06 PM
