16 inch to 17 inch tires change the speedo!
Old Feb 11, 2010 | 10:14 PM
grassyflats's Avatar
scratch this post
Old Feb 11, 2010 | 10:16 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 16 inch to 17 inch tires change the speedo!
You don't change anything by going from a 16 to a 17 inch rim. It's when you change the overall tire diameter that you have to worry about the speedo. You need to change the speedometer gears in the tail of the transmission to correct it.
1986iroc350's Avatar
Car: 1986 Iroc z
Engine: 350 tpi
Originally Posted by grassyflats
via a calculator on a camaro site
going from 16 to 17inch tires changes the true speedometer readout
if your speedo reads you're going 65 with stock 16s thats 65mph
change your wheels to 17 inch and then
your speedometer reads 65 but you are actually
traveling at 69.06mph
Is there a simple adjustment I can do to the speedo
in order to correct this difference and is this adjustment
worth the effort or could it screw everything up ?
Yes more than likely it will change it. You might need to change the speedo gear in the trans.
Old Feb 11, 2010 | 10:35 PM
Stephen's Avatar
Car: 87 GTA
If the overall tire size doesn't change, your speedometer won't read differently.
I went from a 245/50R16 to a 315/35R17 & the speedometer still reads correctly.
Old Feb 11, 2010 | 10:40 PM
Old Feb 11, 2010 | 11:09 PM
Stephen's Avatar
Car: 87 GTA
going from stock 91 Z28 16" rims and tire size to
Ronal R-15s 17x9.5 with 245/45/ZR17s hieght 25.68 "x width 9.65"
I have yet to measure the hieght of the stock tires
there is no change? what?
The stock 246/50R16 is 25.7"
And a 245 fits a 8" wheel. Too narrow for a 9.5" wide wheel. You need a 275.
275/45R17 = (drum roll please....) 25.7"!
Old Feb 11, 2010 | 11:44 PM
You are correct
I did not remember to double check -the posted info on another thread
was incorrect -so now I completely understand this mod does not effect
the speedo
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
