Thinkin about 4th gen, HELP!!!
Old Feb 12, 2010 | 12:04 AM
88 5.7 Iroc-Z's Avatar
Car: 88 Iroc Z, 00 SS
Engine: 5.7 HSR, 5.7 LS1
Transmission: 700r4, T56
Axle/Gears: 3.23, 3.42
hey guys, ok the deal is that some person on my local craigslist has posted a 94 Z28 for 800 bucks, but the thing is that the auto tranny (guessin its the 4l60e) wont shift after 2nd gear,LTI runs like a top but is it worth it,because I read that when the tranny doesn't shift into 3rd or 4th the clutches are screwed, is this true? how hard/expensive would it be to replace or rebuild the tranny?
Thanks in advance
Old Feb 12, 2010 | 12:37 AM
Drew's Avatar
Re: Thinkin about 4th gen, HELP!!!
That sounds like a $1000 fix to me. What's it worth with a good trans? $1800? Assuming you found another one with a good transmission, what are the chances it's not about ready to go out?
4th gens keep getting more attractive as the prices drop. But they're still harder to work on, and have most all of the same problems and build quality.
Old Feb 12, 2010 | 12:44 AM
Damn, do u think I could drop it in my z and hook it up with my 700r4 or r they not compatible
Old Feb 12, 2010 | 08:43 AM
88gta_hiflyer's Avatar
Car: 1988 GTA
Engine: 305 tpi (LB9)
Transmission: WC T-5
Axle/Gears: 3.45 posi
Thanks in advance
I had a transmission (4l60e) go out in my 97 Formula. I got it rebuilt for $1400 which was a good deal. It's probably not worth swapping in a used tranny because they have pretty much all been abused. However, the good news is the engine is way easier to work on with the tranny out so it makes doing a tune up ridiculously easy. You cant possibly appreciate that fact until you've worked on an LT1.
Old Feb 12, 2010 | 09:08 AM
goose88's Avatar
Car: 88 camaro
Engine: 383 stroker
Transmission: th350
Axle/Gears: stock rear end with moser 411s
yes the motor is intechange able but ther willbe some wiring involved. lt1 is almost the same as the motor in your z butit uses front drive dist (optispark) and are very reliable, and have factory roller cams. So if the wireing does not scare you i would say it is worth it. But remember fourth gens are getting harder to find i goog shape. but good luck!
Old Feb 12, 2010 | 09:26 AM
Car: 1988 GTA
Your 88 L98 has a roller cam too.
Old Feb 12, 2010 | 09:29 AM
goose88's Avatar
Car: 88 camaro
Engine: 383 stroker
Transmission: th350
that is true but i belive lt1 are more eficient
Old Feb 12, 2010 | 03:19 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Also know that the LT1 has to be removed from the 4th gen car from UNDER - can't be taken out through the hood - so you'll need a lift for the swap job.
Old Feb 12, 2010 | 09:03 PM
well we have 2 lifts in my shop class, one drive on, and a two post above ground, so it shouldnt be too much of a problem to do, so how much do u guys think I could sell the LT1, rear end, and other parts if I where to part it out?
Old Feb 14, 2010 | 03:16 PM
RobSS1113's Avatar
Not true ! That's one way of taking out the motor, but you can take it out from the top .
And damn I'm glad I live down here with alot of pancho mechanics where the most they charge to rebuild a tranny is 600 bucks.
Old Feb 14, 2010 | 03:50 PM
Car: 1992 RS
Engine: Carbed 350
I've always read everywhere that the 4th gen motors had to be dropped instead of lifted, but if you've done it out the top, then cool. I know I'd hate to try and take the LT1 out the top of my 1997 - looks like the entire front end would have to come off!
Old Feb 14, 2010 | 09:33 PM
RobSS1113's Avatar
yeah its tricky ... I hope there is not a "next time" but Maybe there will be one at my friends shop and I will take pictures of the motor coming out thru the top !!
Old Feb 15, 2010 | 10:10 PM
Originally Posted by goose88
yes the motor is interchangeable but there will be some wiring involved. lt1 is almost the same as the motor in your z but it uses front drive dist (optispark) and are very reliable, and have factory roller cams. So if the wireing does not scare you i would say it is worth it. But remember fourth gens are getting harder to find i good shape. but good luck!
Are you referring to the wiring harness and that stuff, I would have the parts car which is complete so I would have all the stuff needed for the swap, also could I just put a 700r4 in a 4th gen, cuz there are many around here for pretty cheap too
my86bird
Oct 23, 2015 12:20 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
cam-mike
Aug 24, 2015 07:23 AM
