92 Firebird 305 TBI crank but won't start
Old Feb 15, 2010 | 10:00 PM
zoso0330's Avatar
I picked up a 92 Firebird 305 TBI the other day. My problem i am having is the car will crank but not start up. when i turn the key on the fuel pump with prime up but won't turn off after two seconds. I have 13 psi steady pressure. Rebuilt the Throttle bodies but still have old injectors in it. Fuses are good and the tried a different Fuel Pump Relay to see if that would work. Tried it in nuetral and park. Has a new battery, distributor and rotor.
Going to try new spark plugs and wires because i have them sitting here.
Im pretty confused as to what i should look at next.
oh and when i have key off the manual says to push on accelerator peddle to see if fuel sprays and it doesn't not.
any ideas would be very appreciated because this is my only ride to work and i am tired of walking lol.
Old Feb 15, 2010 | 10:01 PM
zoso0330's Avatar
Re: 92 Firebird 305 TBI crank but won't start
oh yes and when i use starter fluid and or pour gas down TBI it will start and run just fine.
Old Feb 15, 2010 | 10:02 PM
zoso0330's Avatar
and it has new fuel filter
Old Feb 15, 2010 | 10:13 PM
grdpdr305's Avatar
Car: 91 Camaro RS
Engine: 305 E85 TPI
Transmission: T-56 Aftermarket
Axle/Gears: 10 Bolt 3.73 TrueTrac
If that engine fires when you put a tsp, or so of gas down the throttles then you have a fuel starvation problem. This rules out the ignition so don't even mess with it. If you have fuel pressure to the TBI then this rules out the pump. Check all your electrical connectors to the TBI, you might even be able to check your codes by jumpering your ALDL and see how many flashes you get on the Service Engine Soon light (SES), and that might give you some info on whats wrong.
Old Feb 15, 2010 | 10:15 PM
zoso0330's Avatar
hmmmm alright by chance do you know which spots to jump on the ALDL to get the SES lights?
Old Feb 15, 2010 | 10:22 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
You could borrow some of the test kits from Oreilly and see if the TBIs' are getting signals pulses from the ignition module. I found on my 89 GTA, we had turned the distributor coil so far in setting the timing that the plug came out of the ignition module. Plugged it back in and the car ran fine.
Old Feb 15, 2010 | 10:51 PM
zoso0330's Avatar
so i just looked at the lights when i turn the key on the SES light doesn't even light up. and if i jumper A and B to see if i can get codes it won't light up either. but if i crank it a min and let the key go to back to run it will flash twice then turn off
Old Feb 15, 2010 | 11:15 PM
zoso0330's Avatar
wow yep now i got more problems i think with no SES light
Old Feb 15, 2010 | 11:33 PM
zoso0330's Avatar
not quite sure where to go with this now any suggestions
Old Feb 16, 2010 | 11:29 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Ignition module plugged in correctly?
Old Feb 18, 2010 | 04:29 PM
zoso0330's Avatar
yeah looks like its plugged in correctly. i just hooked a test light up to the injectors on the throttle body and the light doesn't go off when key is turned over. the pump doesnt' turn off after 2 seconds when pressurized and the SES doesn't flash unless you turn the car over and let go to run position. i think im at a ECM issue. is that a good assumption?
Old Nov 16, 2010 | 03:24 PM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
I have the same problem with my 89 Bird, if you figure out whats wrong please let me know! Im getting pissed because i cant figure it out. Ive replaced the spark plugs, oil, and fuel pump. Not sure if im getting fuel pressure through the lines. How could i check that without a pressure gauge?
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
Tonyy_z
Aug 12, 2015 07:20 AM
MENINBLK
Aug 5, 2015 11:58 PM
