Intake manifold bolt torque spec.
Car: 1988 Pontiac trans am
anyone know the torque specs for the intake manifold bolts on a 88 lo3?
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Re: Intake manifold bolt torque spec.
I believe it to be 30 foot pounds. you might want to double check that.
They are 30 foot pounds. I recommend putting them in at 10 foot pounds at a time till u reach 30 so you will have to tighten the manifold three times . This will tighten the manifold more evenly. And just a few extra pounds shouldn't hurt but be careful because to much can cause the manifold to crack
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
And make sure you get that manifold to lay flat by starting with the centre bolts and then working your way out in a spiral pattern.
No point in over-tightening them... no benefit to be had, only risks of damage.
Just do them to the right torque and move on.
ambainb
Apr 25, 2016 09:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
