Z28 engine issue need help I'm stumped
Old Feb 25, 2010 | 12:37 PM
Christinthez28's Avatar
Okay so here is my problem when I have the car idling or cruzing around or about 2000 rpm and she is all nice and warm (which is about 235) she hits this wall Which I think is limp-home mode and back fires and sputers and when I let up on the gas the rev it it's okay but when I try to move again it sputers and it feels like I'm running on 2 cylinders I looked under the hood and my exhaust manifold is glowing cherry red. There are no mods to the car and it's a 5.7 tpi, and it isn't throwing a code. Iv anybody has any clues that would be great cuz I'm stuped
Old Mar 4, 2010 | 09:06 AM
Re: Z28 engine issue need help I'm stumped
Okay so I took everybodys advice from another forum and I cut out the cat and removed the yhermastat to see if that helped keep the car cooler and I replaced the violent temp sensor I also replaced the distibutor and rotor button cause the were shot I wa amazed that I even had her running. After all that I thought I fixed it I got about a weeks worth then she started acting up again and blew my muffler of doing about 45 so now I'm confused again but when I cut the cat out the pipes had so much carbon in them that it looked like a draino commercial. Anybody got any other Ideas?
Old Mar 4, 2010 | 09:55 AM
wildjyoung's Avatar
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
Have you confirmed that you timing is correct? It sounds like it is way off.
Old Mar 4, 2010 | 11:04 AM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
As mentioned earlier check the timing but if not it sounds like your running lean. Pull the spark plugs Ill bet there probably dead white maybe even blistered or possably coated with a black powdery substance. Check for things like vacuum leaks, EGR valve, fuel pressure ect. Are you sure that your check engine light works? Try doing a vacuum test also.
Old Mar 4, 2010 | 11:49 AM
manolis1969's Avatar
Car: klowny1969 <-youtube 4 3rd gen vids
Engine: subscribe to klowny1969 on youtube!
Transmission: subscribe to my channel on youtube
Do a COMPLETE full tune up first..means fuel filter, wires plugs air filter blah blah..then check timing...then also clean up your throttle body with intake cleaner..see how she runs..if u still have issues then you look into other things..check also for codes..
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
cstrobel65
Aug 15, 2015 10:19 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Elliswon
Aug 10, 2015 12:33 PM
