Car problems nothing happen when truning key.
Want a title? Post!
Car: 1984 Z28 Roadter AutoForm vert.
Engine: L69-HO
Transmission: 700-R4
I was driving my 1984 Camaro Z28 and it suddenly fell dead. I coasted to a stop put the transmission into the parked position and turned the key to the start position and nothing happen. The starter did not engaged matter of fact nothing worked when I turned the ignition to ACC, Start and Run positions. I checked the battery cables and they were okay. I turned on the lights and blew the horn while turned the ignition key to the start position the lights and horn was not affect in any way. Everything works that is wired hot and nothing works that engineered to work when the key is turned to ACC, Start or Run position. I checked the fuses and replaced the alternator because it was bad. Whats seems to be my problem?
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: Car problems nothing happen when truning key.
so the lights work and stay on even in the crank position??? you could have dirty connection at batt terminals. Also you might wanna check to see if you have power at the starter trigger wire while cranking (need two people to do this)....if you do you may have a bad starter. If no power down at starter I would suspect the ignition switch.
It sounds like your actual ignition switch, not the lock cylinder, is bad.
What I gather is everything that works without a key in the car, works.
Everything that normally works with the key in acc/on position, does not work.
Ignition switch.
Ignition switch.
Car: 1986 Pontiac Firebird
Engine: 357ci 400hp 4BBL
I dont if it helps but I had a problem similar to this and I found out the engine coolant level was low. After I filled it up and let the car sit overnight it started right up.
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Do you have tilt-wheel? Since our cars use a metal rod to actuate the ign switch, tilt-wheel can mess that up (I can not start my car if my steering wheel is too high up).
Car: 1991 Pontiac Trans Am
For what it's worth, I had the exact same thing happen a long long time ago. It turned out that my new really expensive accel dfi computer system fried itself while driving down the road. I was able to unplug the dfi computer and use the stock computer which got everything running again. So, maybe the stock computer fried itself.
Fixed my problem. I had checked everything topside, finally got underneath to check the fusable links at the starter. One was fried. A new wire nut and I'm ready to go. Thanks for the suggestions.
And remember, no matter how bad it seems, it's always something simple.
db057
Aug 11, 2015 10:11 PM
