Droping the oil pan with engine in car?
Old Feb 27, 2010 | 09:36 AM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Can you drop a 3rdgen v8 oil pan with the engine still in the car with out getting hung up on anything like the pick up?
Old Feb 27, 2010 | 09:52 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Droping the oil pan with engine in car?
you can drop it a few inches with the engine jacked all the way up but the oil pan will not come out. maybe if the tranny and flywheel are removed
Old Feb 27, 2010 | 09:53 AM
Vader's Avatar
While the engine is still technically in the car, you will need to raise the engine to remove the pan.
Old Feb 27, 2010 | 10:05 AM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
You should be able to if I remember right, but the dizzy cap and/or the whole the dizzy needs to come off and the motor jacked up as far as you can get it.
Old Feb 28, 2010 | 06:50 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
To reiterate:
Remove dizzy cap
disconnect exhaust from manifolds/headers
pull the through bolts on the motor mounts
Put the timing mark on the balancer at 6 o'clock
jack up engine 2.5 - 3"
pull pan
It'll come out.
maroe624
Apr 16, 2017 08:29 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
B_Dubya
Aug 26, 2015 05:09 PM
MY87LT
Aug 17, 2015 08:43 AM
gwade12
Aug 8, 2015 08:17 AM
