Timing Marks on TPI engine
Old Mar 1, 2010 | 02:09 PM
Seedy Al's Avatar
hey guys
So Im not really fimilar with these engines, just trying to time up an engine to 10 degrees BTDC to run an aftermarket ecu.
its a 5.7 TPI
Looking at the marks, I asssume the Big V is TDC, so what size steps are the others?
My sweet ms paint drawing
Any help would be most awsome
Allan
Old Mar 1, 2010 | 02:17 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: Timing Marks on TPI engine
You are correct. The big V is 0 or TDC. To the left of that in your drawing (or towards the passenger side) is B.T.D.C. This is where you will want to be. Each notch is an additional 4 degrees.
Old Mar 1, 2010 | 04:04 PM
Seedy Al's Avatar
fantastic! cheers for that. totally wasnt sure what degree each notch was so that is perfect. thanks
midge54
Dec 27, 2019 04:14 PM
Wade787b
Sep 29, 2015 01:15 PM
The_Phoenix
Sep 3, 2015 10:56 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Thirim
Aug 9, 2015 06:19 PM
