valve springs
Old Mar 3, 2010 | 09:01 PM
Tyrel2018's Avatar
Car: 1989 Camaro RS
Engine: LO5 350
Axle/Gears: 3.42 posi
valve springs
might be a stupid question but i am at a loss. i need to get valve springs that will have atleast .550 lift and all i can find is the lbs./in. Rate and i dont know what that means. is there anyway that i can tell what i need to get? i have no clue what i need to get so any help would be appreciated, thanks Ty.
Old Mar 3, 2010 | 09:18 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: valve springs
Max lift is the difference between the solid height and the installed height. There's a lot more to choosing a valve spring than just the max lift figure.
Old Mar 4, 2010 | 07:37 PM
Tyrel2018's Avatar
Car: 1989 Camaro RS
Engine: LO5 350
Re: valve springs
i know that there is just more then the lift just the only thing that has me stuck right now is getting the right lift, thanks though
Old Mar 4, 2010 | 09:18 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
Re: valve springs
I dont really know right off how to tell, but I am using lt4 springs for a 5.25 lift cam and they work just fine but they came in the kit with cam. I would search thru google and get the answer.
pjsparts
Oct 29, 2025 06:39 PM
crzycamaro86
Sep 12, 2015 05:51 PM
ericjon262
Sep 11, 2015 06:07 PM
lakeffect2
Sep 7, 2015 03:52 PM
