Engine dies at idle and backfires between shifts
Old Mar 6, 2010 | 10:17 PM
scottb0119's Avatar
Hello all,
New here and have a 88 IROC with the 305. Recently replaced the distributor put new plugs wires cap and rotor. I set the timming to 4 deg before TDC. Some days the car runs good, then others not so. On bad days it will die everytime I push in the clutch. When shifting you can hear kinda a "bubbleing" sound out of the muffler, I know thats a funny description but its a sort of back fire although not a loud shot. I dont know what else to check, sounds like a timming issue but it seems to be where its supposed to be. Thanks for any input.
Scott
Old Mar 6, 2010 | 11:52 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: Engine dies at idle and backfires between shifts
What procedure did you use to set the timing? Is this a carb?
Old Mar 9, 2010 | 11:16 PM
scottb0119's Avatar
Its fuel injected, I removed num 1 plug, put my finger over the hole and manually turned the engine over till it blew my finger off. I then set the rotor roughly between num 1 and num 8 plug wires. Then fine tuned the timming with my timming light.
jklein337
Sep 19, 2018 06:23 PM
Andrew6.688
Dec 13, 2015 10:59 AM
backtothe80s
Sep 5, 2015 12:39 AM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
