Could my water pump be bad?
Old Mar 9, 2010 | 07:34 PM
DemonYusuke's Avatar
Car: 1991 z28 L98 Spec
Engine: 5.7 350 TPI 245\345
Transmission: 700 R4
Im having and over heating issue, first my fan isnt running anymore i need to solve that, but I replaced my thermostat as well and when it hits 195 it dies down about 5 degree's telling me that the valve opened, but then it shoots up again and doesnt go back down. This is leading me to believe that the water pump isnt circulating the cooler water. Could this be the case? Any suggestions?
Old Mar 9, 2010 | 07:47 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Could my water pump be bad?
possible,but very unlikely-the impellers are pretty
secure on chevy waterpumps,so as long as the pulley
is turning it should be pumping.
Old Mar 9, 2010 | 10:02 PM
I feel the same way never had one fail before, but I dont know what else could be causing it to over heat so bad.
Old Mar 9, 2010 | 10:38 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
so are you saying that your car overheated prior to replacing the thermostat? if your car was overheating prior, it could be a timing issue and or a faulty radiator, there of course are other internal possibilities...
your Radiator could be plugged... what you could do is siphon enough coolant from the radiator, fire up the car and allowing the thermostat to open up, once the thermostat opens up you should see the coolant flow, if you don't see the coolant flow, then you radiator could be plugged...
Old Mar 10, 2010 | 11:04 PM
I thought of that too, and tomorrow I am planning on testing the radiator, I finally got the car running properly now just need to fix the over heating issue and shes set, but my gauges are still messed up to
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
Newguy91rs
Aug 7, 2015 09:51 PM
