Freeze plug question
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
I've got my engine totally apart and on a stand right now. Should I replace the freeze plugs as long as its apart? None of them leak and they look to be brass from the factory.. I was going to just leave well enough alone but they're so cheap and easy to get to right now I'm having second thoughts.
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: Freeze plug question
If you don't need to clean out your water jackets, then you don't need to remove them. Most blocks I work on need extensive cleaning, so they come out.
