92 engine issues/ possible ecu
Old Mar 13, 2010 | 06:19 PM
DemonYusuke's Avatar
Car: 1991 z28 L98 Spec
Engine: 5.7 350 TPI 245\345
Transmission: 700 R4
When it starts an idles every once in a while it will die down and almost stall but it comes back, when put into gear it almost dies then revs up again, and the more you press the pedal the more it bogs down, if you floor it it takes probably 10 secs to reach 25 30 miles an hour. Any Ideas, I think its either fuel pump, or ecu, im not sure
Old Mar 13, 2010 | 06:57 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 92 engine issues/ possible ecu
Have you got SES light? Pull codes and see what that tells you.
Old Mar 14, 2010 | 07:22 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Check your fuel pressure.
Old Mar 14, 2010 | 10:32 PM
thanks for the suggestions, i ended up swapping the ecu and now she runs like a champ
eightsixseven
Dec 16, 2024 01:50 PM
Caspar
Jun 19, 2016 11:19 PM
E Rod
Aug 28, 2015 05:17 AM
nuggie
Aug 25, 2015 01:27 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
