Loose steering?
Car: 1990 camaro rs
Engine: 305 tbi
Loose steering?
Ok guys I have a 90RS and my steering has some play in it, I have to move it a good two to three inches before it actually starts turning. My question is howcan I tighten this up?
Thanks Tim
Thanks Tim
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Loose steering?
First thing to check is the rag joint. If that isn't the problem check the center drag link and you can try adjusting the steering gear. Instructions on adjusting the steering gear can be easily found with a search.
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Loose steering?
what's a rag joint?
Re: Loose steering?
have someone turn the wheel back and forth (engine off) while you look to see where it's loose.
Car: 1992 Camaro RS
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Loose steering?
JamesC
Car: 1990 camaro rs
Engine: 305 tbi
Re: Loose steering?
thanks Tim
Re: Loose steering?
http://www.spohn.net/shop/1982-1992-...GM-F-Body.html
Not difficult to do with basic hand tools. The car would require alignment afterward.
JamesC
Re: Loose steering?
I have the same problem. However, the car responds immediately to the left and has the play on the right. I haven't had a chance to get a friend to turn the wheel so I can try to locate the play.
Car: 1990 camaro rs
Engine: 305 tbi
Re: Loose steering?
Not broken and worn out are two different things, I think. Here's a link to show you what's what:
JamesC
JamesC
thanks again Tim
Car: 87 GTA
Re: Loose steering?
Is it not only turning the steering wheel that haws a problem? But also able to tilt up & down, without touching the tilt lever?
If so......https://www.thirdgen.org/steeringcolumn
Fairly complex job with specialized tool, so I paid to have mine done. $100 later & it was better than new!
sjorgens
Oct 1, 2015 07:54 PM
