Getting my car out of storage
Car: 85 trans am
Engine: 305 tpi
Transmission: 5 speed
So I stored my car at my parents condo 120 km from where Im living. When I stored it I took out my amp and sub. I also took the negative post off the battery. 2 months ago I went down to check on he car and to start her up. Had to jump the car, it ran great until I started driving around the underground and went over a speed bump. After this, the engine started cutting out, as if a kill switch was pulled. But I could give it gas and keep it running, it had no throttle response.
Whats going on here guys? Do you think this could be from a loose battery connection.
Transmission: 4L80E/4L80E
Probably not. The engine will run just fine off of the alternator with the battery completely removed from the car after you get it started.
But, it probably is a loose electrical connection someplace. Ignition is usually a good place to start looking.
Linson
Aug 21, 2015 02:12 PM
NBrehm
Aug 5, 2015 07:57 PM
