removing AC, help please
Old Mar 23, 2010 | 01:33 AM
FlippindaBird's Avatar
Car: 1987 Firebird, Dad bought it new
Engine: 5.7L Vortec w/ LT4 Hot cam
Transmission: 700r4 transgo shiftkit 2600 stall
Axle/Gears: 3.42 '02 SS 6 spd rear
i am about to remove the ac from my car and i am wondering if there is a plug or something i can get to block off where the condenser is. i am inserting a pic of the condenser to be sure i am calling this object by the correct name lol thanks for all your help
Old Mar 23, 2010 | 01:03 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Loosing His Cool
That is not the condenser, that’s the accumulator.
You want a cap.
If I remember correctly, you need a ¾-16 NPT.
Happy Racing!
“Push On Bumper To Spin”
Old Mar 23, 2010 | 01:15 PM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
Re: removing AC, help please
gj Nina. "loosing his cool"
Old Mar 23, 2010 | 01:19 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
are you removing the accumulator completly?? if not then cap.
If so you can get a a/c delete plate made for the 1le cars. I have seen a few of them on ebay. You can also get the idler pulley that goes in place of the a/c pump as well.
Old Mar 23, 2010 | 09:16 PM
can i just remove it without the delete kit? like cap behind it? also is the puller nesecary i dont have a serp drive i have V belts so i figured i could just remove it all and be good
Old Mar 23, 2010 | 11:19 PM
pantywaste33's Avatar
Car: 1984 z28
Engine: 5.7 vortec crate
i didnt even cap mine when i removed it. and you dont need a pulley if its a separate belt for the ac. heres one of the best pics of mine. i run a v-belt. and if thats whats on your ac then all you gotta do is just pull it.
Old Mar 24, 2010 | 09:05 AM
very cool, thats what i thought but wanted to be sure before i starter removing things, did you use the stock bracket to remount your PS when you installed the headers i cant really tell from the pic, thanks again im actually going out to delete the AC right now
Old Mar 24, 2010 | 11:15 PM
Car: 1984 z28
ya i used the stock bracket but i had to cut it where the ac is supposed to bolt, then in put a bolt in the hole where it bolts to the ps bracket and it works fine.
Old Mar 24, 2010 | 11:21 PM
Gregzz4's Avatar
Car: '78 GMC Sierra Heavy 1/2
Engine: GMPP ZZ4 Q-Jet
Transmission: 700R4 Stage 2 w/Race Internals
Axle/Gears: 10 Bolt 3:42 Eaton
If you think that sometime down the road you may get your A/C up and running again, or for resale value, cap off all your parts well
You do not want any excess air/moisture getting into the future re-usable parts
It will render them useless
Old Mar 25, 2010 | 08:33 AM
thanks greg i would have never thought about that, i do wanna use the ac in the future just dont need it now cause i dont ever drive it and ill prolly only drive it a few times to the track and back in the summer, besides it rarely ever gets over 90* here i can always roll down the windows lol i like the room that it gave me in the engine bay its all out im gonna get to the store today and get caps for everything i think ill just get another stock bracket and mod that one to work with my headers so i still have the one that mounts the AC thanks for all the info guys
Old Mar 25, 2010 | 09:17 PM
Gregzz4's Avatar
Too bad I didn't catch this post before you removed your lines. 'The' sensitive piece in your system is the Receiver/Dryer, that big shiny can in your pic with the pressure switch on it. The can is full of dessicant and absorbes any moisture in your system.
It's OK though..if it's ruined they're not that much $. Consider replacing it new if you ever hook it all back up again.
And for now you can just use 2-60 Air Conditioning
2 windows open @ 60 MPH
Old Mar 25, 2010 | 09:33 PM
thanks again greg, i think ill use 2-120 though should work better, seeing how the headliner is gone from previous use of said AC i think there will be less colateral damage this time around
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
