Brake problem?
Old Mar 23, 2010 | 09:37 AM
84camaro18's Avatar
Car: 84 Camaro Sports Coupe
Engine: Stock 305
Brake problem?
okay so i got a 87 camaro (v6) for $200!! wouldnt crank so i put a new fuel pump and she fired right up well anyways my car will start up and idle but i barely have brakes.i I've noticed that its mostly when im idling or going slow but when im cruising down the street i have brakes. what could be the cause of this? when i say i barely have brakes i mean i have to push the pedal to the floor to stop (& its kind of hard to push) does this sound like a vacuum leak? any help is greatly appreciated. thanks!
Old Mar 23, 2010 | 12:19 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Re: Brake problem?
Check the line to the brake booster, fluid level, bleed the system.
Old Mar 23, 2010 | 12:56 PM
racethesunlive's Avatar
Car: '92 Camaro
Re: Brake problem?
First thing to do is check all your vacuum lines (especially the one going from the brake booster to the plenum) for cracks and/or missing connections. It sounds like you have a slight vacuum leak but as your RPMs move higher (when your going faster) your getting enough vacuum to power the brakes correctly.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
overdriv
Aug 20, 2015 03:52 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
