No High Idle on cold Start up.
Old Mar 25, 2010 | 09:04 PM
JP007's Avatar
Car: 89 Formula
Axle/Gears: 9 Bolt 3.27
I started my 89 Bird with a 305 TBI and I no longer have a high idle speed on initial start. Runs ok but no high idle. Ideas?
Old Mar 25, 2010 | 11:22 PM
Ilike2stroke383's Avatar
Car: 1987 Gta Trans Am
Engine: 383 Stroker
Transmission: t-56
Axle/Gears: 3.47 02 SS rear end
Re: No High Idle on cold Start up.
Not completely sure, but could be a coolant temp sensor or maybe o2 sensor defective, making the car think its already hot on start up and defaulting to closed loop.
Old Mar 26, 2010 | 10:01 PM
JP007's Avatar
Car: 89 Formula
Thanks for some ideas much appreciated.
JP
Old Mar 27, 2010 | 03:23 AM
Engine: 383 Stroker
Transmission: t-56
JP
No problem. You can find out whats wrong more effectively by 2 ways. Easiest would be a scan tool. Just crank it up and see what values are for the 02 sensor and check freeze frame data from crank up and check coolant sensor. Next would be a multimeter. Look up what values the sensors SHOULD be at and see what you actually have and go from there. Good luck.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
