Car won't start
Old Mar 28, 2010 | 02:21 PM
Xgallegos4's Avatar
Car won't start
I have a brand new battery and changed the fuel filter but it still won't start. When I spray starting fluid on the carb it starts up for 2 secs then shuts off even if I press the gas it still ***** off. It's a 1990 rs camaro with a 5.0 305 any help is appreciated
Old Mar 28, 2010 | 02:23 PM
redfox's Avatar
Car: 91 rs, 97 firebird
Engine: 3.1, 5.7
Transmission: both 700r
Re: Car won't start
can you hear your pump come on?
Old Mar 28, 2010 | 02:25 PM
Xgallegos4's Avatar
Re: Car won't start
Were can I hear it at?
Old Mar 29, 2010 | 08:06 PM
redfox's Avatar
Engine: 3.1, 5.7
Re: Car won't start
in the gas tank. when you turn the key on you should hear a buzz for a short time, its your fuel pump building pressure.
Old Mar 29, 2010 | 09:27 PM
Xgallegos4's Avatar
Re: Car won't start
Ok I'll check that out also weres the fuel pump relay I was told to check and see if it's plugged in or something
Old Mar 30, 2010 | 09:58 PM
redfox's Avatar
Engine: 3.1, 5.7
Re: Car won't start
you might also want to make sure your geting the right gas psi
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
