One working Injector question...t.b.i.
Old Mar 28, 2010 | 08:39 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
My 305 tbi has been running like crap the last week or so...I am doing a complete tuneup and noticed one injector not firing while idling. At idle the driver side injector emits no gas. It does shoot a bit on start up but after that nothing.
Do I just change the injector since I am getting electrical power to the injector on start up?
Oh yeah it's doing it on my 92 RS...
Old Mar 28, 2010 | 08:50 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Re: One working Injector question...t.b.i.
Do more testing before switching the injector. Look up the test procedure, you may have a bad wire or it could lie in the comp. It may just be a stuck injector. You could swap the 2 injectors and see if it stays on the same side.
Old Mar 29, 2010 | 09:25 AM
Axle/Gears: Posi
I could not find the testing procedures other than the ohms test. I don't have an ohms tester. Is there another route or way of testing?
Old Mar 29, 2010 | 09:41 AM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Another test is to use a noid light for the connector. Disconnect the injector, Connect the noid to the injector electrical connector one at a time. Crank the engine, watch the light flash, it should flash the same on both connectors. This makes sure you are getting correct voltage signal to injector. You should try to do the ohm test or swap injectors.
Old Mar 29, 2010 | 09:46 AM
Axle/Gears: Posi
I don't have a noid light. Limited tools on stuff like that. But I can swap the injuectors. I am leaning towards just replacing the injectors since time is a factor and I only have one car this week.
1992rs/ss
Jan 31, 2025 05:10 PM
specialized
Jun 18, 2022 09:26 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
