Coolant Temperature Sensor
Old Mar 29, 2010 | 01:58 PM
lo-z's Avatar
Car: 98 Chevrolet S10
What is this thing? It's mounted on the thermo housing. What will happen if it's removed?
Old Mar 29, 2010 | 02:28 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
With wires or with hoses attached to it?
Old Mar 29, 2010 | 02:49 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Re: Coolant Temperature Sensor
Pic?
Old Mar 29, 2010 | 02:50 PM
lo-z's Avatar
Well, Acually both, but mainly the one with wires.
Old Mar 29, 2010 | 02:57 PM
lo-z's Avatar
here is the engine with the thermo housing plugged.
Attached Thumbnails Coolant Temperature Sensor-photo0231.jpg   Coolant Temperature Sensor-temp-sensor.jpg
Old Mar 29, 2010 | 04:00 PM
five7kid's Avatar
That provides engine temperature information to the computer. Without it, the computer will make incorrect decisions.
Old Mar 29, 2010 | 04:03 PM
lo-z's Avatar
What kind of decissions?
Old Mar 29, 2010 | 04:16 PM
five7kid's Avatar
Going closed loop instead of staying in open loop for one. In open loop, you aren't getting proper mixture and timing control, or torque converter clutch lock-up.
Old Mar 29, 2010 | 05:37 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
When mine was unplugged before it ran like crap and barely stayed running.
Old Mar 29, 2010 | 06:03 PM
lo-z's Avatar
OK, that would explain the idle being at 500 rpm. Runs much stronger though. I just replaced 10 year old spark plugs, wires, cap and rotor. I also stripped all the emmissions junk and switched to a serpentine setup.
Old Mar 30, 2010 | 07:06 AM
lo-z's Avatar
Ok, I put the sensor back on and it still idles low.
Old Mar 30, 2010 | 05:59 PM
five7kid's Avatar
500 RPMs in drive is the factory spec for idle speed for LG4 3rd gens. However, the computer doesn't control idle speed. It can affect idle speed, but doesn't control it.
Old Mar 30, 2010 | 06:01 PM
five7kid's Avatar
I also stripped all the emmissions junk...
What all did you remove?
Old Mar 30, 2010 | 06:54 PM
lo-z's Avatar
I removed the whole smog system, Heater core hoses, the charcoal filter canister and all hoses associated with it, that plastic ball thing that was near the charcoal thing. Plugged holes in exhaust manifold, intake manifold, and carb. I also changed from V-belts to serpentine.
500 rpm is in neutral.
Old Mar 31, 2010 | 06:57 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
coolant temp sensor. Did you replace it with a new one? They only run about fifteen bucks. Do you have any codes? Check your IAC valve. It may be dirty or need to be reset. Google on how to set the IAC valve/thirdgen
Bubbajones_ya
Jul 6, 2024 08:32 PM
92firebirdguy
Sep 1, 2016 07:53 AM
BWilcox
Sep 20, 2015 12:19 PM
m00n420
Sep 11, 2015 02:39 PM
FormulasOnly
Sep 10, 2015 09:07 PM
