what is this sensor
Old Mar 30, 2010 | 08:45 PM
89RSTBI's Avatar
Car: 89 RS, 93 Z28
Engine: Vortec 350 TBI, Lt1 6 Speed
what is this sensor
My sensor that is in between the 6 and 8 spark plug has broken off (don't know when it happened) but was wondering if anyone can tell me what its called so i can order a replacement. The engine is from a 89 RS and its a 305 TBI engine. if you need any additional information please let me know
Old Mar 30, 2010 | 08:50 PM
1986iroc350's Avatar
Car: 1986 Iroc z
Engine: 350 tpi
Re: what is this sensor
Just guessing without a picture i believe its a temp sensor. It should have a wire going to it. But then again.. Its broken. Is there a loose wire somewhere? does your temp guage work on the dash?
Old Mar 30, 2010 | 09:27 PM
89RSTBI's Avatar
Car: 89 RS, 93 Z28
sorry i guess i should have been more specific. The engine is out of the car and I am rebuilding a Vortec 350 to go back in. it did have a wire hooked to it (don't know what it looked like to be honest though). It is broken and the only think left to the sensor is the hex head so a picture really wouldn't help. I do have a sensor on the intake at the thermostat housing and I thought that was the temp gauge sensor. Anyway if anyone knows which sensor goes in this spot and what the part number or at least what its called I would appreciate it
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
x2 temp sensor. It has a harder like line ran to it i believe.
Old Mar 30, 2010 | 10:08 PM
89RSTBI's Avatar
Car: 89 RS, 93 Z28
thumbed through the whole repair manual and see nothing about a X2 sensor
Old Mar 31, 2010 | 01:12 AM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Hello 89RSTBI!!
Usually that would be a temp sensor for the cooling fan, and not for the temp gauge/dash light, as that's on the other side between #1, and #3 spark plug holes!!
Check your repair manual again!!!
Old Mar 31, 2010 | 01:17 AM
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
this sensor busted for me too. Where do you get a replacement?
Old Mar 31, 2010 | 01:49 AM
89RSTBI's Avatar
Car: 89 RS, 93 Z28
yes I have the one from the other side (same side the oil pressure sensor is on, drivers side) this one is on the passenger side and cooling fan sensor makes sense. I was looking for x2 sensor in the manual and only think close to that was the oxygen sensor thats in the manifold but thats not what this sensor is. I will look for fan sensor
Old Mar 31, 2010 | 02:00 AM
89RSTBI's Avatar
Car: 89 RS, 93 Z28
I think I found it and its called a Cooling fan switch or Thermal Control Fan Switch and the stock part number is 14043276
Old Mar 31, 2010 | 02:15 AM
Hello Grumbles!!
Try the GM dealer, Autozone, NAPA etc!!
The sensor "should" still be used on GM stuff, and should be available from them!!
Old Mar 31, 2010 | 02:19 AM
Hello 98RSTBI!!
That's it!!
Comes in different temps for other applications, of course, they would have different part numbers!!
Old Mar 31, 2010 | 10:26 AM
Grumbles's Avatar
Last time I hit up the dealership lookin' for one of these the guy told me it would be $120.
I ended up buying a $30 radiator sensor probe kit
Old Mar 31, 2010 | 12:46 PM
89RSTBI's Avatar
Car: 89 RS, 93 Z28
there are plenty AC Delco parts on ebay for around 19 bucks
Old Mar 31, 2010 | 06:23 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
ok on my 91 tpi that sensor is a coolant fan switch. It turns on the secondary fan. There is a coolant temp sensor on the front of my block by the thermostat housing and on the drivers side of the block there lies the temp gauge sensor, between the one and three cylinder. Do you have a dual fan setup? If you do then, Why dont you just take that existing wire that went to that sensor and wire it to a switch inside your car, so you can turn on that fan any time you want. I wired mine to the foglight switch on my dash.LOL
Old Mar 31, 2010 | 06:26 PM
89RSTBI's Avatar
Car: 89 RS, 93 Z28
think I would rather spend the 19 bucks or 40 bucks for one that turns it on faster. I would never hot wire a fan because what if someone else was driving the car and they didn't turn on the switch? bye bye engine. I just don't think that is a good alternative
Old Mar 31, 2010 | 07:07 PM
ninetyone's Avatar
Axle/Gears: 3:42
I was referring to wiring the secondary fan to a switch, not the main fan.LOL
Old Mar 31, 2010 | 07:10 PM
89RSTBI's Avatar
Car: 89 RS, 93 Z28
oh ok, I guess I misunderstood. Mine is a single fan
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
