IAC question
Old Mar 29, 2010 | 03:50 PM
T-rocZ88's Avatar
Car: 79 cutlass
Engine: sbc
Transmission: th-350
Axle/Gears: 12bolt
IAC question
The car surges at idle, I just picked the car up and the previous owner replaced the IAC. I was told it needed to be reset by unplugging it and grounding something out.......how do I reset it to get it to idle nicely. It's a 350 TPI in a 89 t/a thanks!
Old Mar 29, 2010 | 06:54 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: IAC question
I dont think its the IACs fault the surging idle is usually the EGR valve requiring attention.
Old Mar 29, 2010 | 08:22 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Re: IAC question
Yep, surging is usually caused by a lean condition and the EGR could be causing that.
I can post the IAC re-setting procedure if you still need it. It involves jumpering the ALDL, key "ON", IAC disconnect, etc., etc. It's not too involved but rather than me trying to go from memory, and possibly getting something out of order, I'd prefer to find it in one of my saved files before posting.
Jake
Old Mar 29, 2010 | 09:59 PM
T-rocZ88's Avatar
Car: 79 cutlass
Engine: sbc
Axle/Gears: 12bolt
Re: IAC question
Ok, if it helps the car even has surges at low rpm while driving, it seems almost like a
fuel problem, the pump is new but it's VERY loud for some reason.......this is why my race car is carbureted lol!
bamaboy0323
Sep 3, 2015 06:07 AM
86IROC112
Aug 21, 2015 07:20 PM
86IROC112
Aug 21, 2015 12:39 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
