I have posi?
Old Mar 31, 2010 | 02:25 PM
Firebird Mess85's Avatar
Car: 85 Firebird & Grand Prix GXP
Engine: LG4 305 (originally 2.8L V6)
Axle/Gears: 10 bolt 3:43 Open Diff.
I have posi?
So I just put a new distributor cap, rotor, and coil on and I went from one wheel peeling to both. Is it usual for a possible power gain from these replacements to cause the posi to kick in? I've always only had one wheel going in the past.
Old Mar 31, 2010 | 02:40 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: I have posi?
the easiest way to see, jack up the rear wheels and rotate one wheel and see what the other wheel does. you may have just had even weight transfer at that moment.
Old Mar 31, 2010 | 03:26 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: I have posi?
Since the car was originally a V6, I suggest that the rear is open. To verify, however, you might pop the cover and take a peek.
JamesC
Old Mar 31, 2010 | 03:27 PM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
Re: I have posi?
Second easiest way is to change the diff like I did. It probably needs a changing anyway.
Old Mar 31, 2010 | 04:09 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: I have posi?
I think skirkland1980 hit it best. Not that JamesC is wrong, but probably no good reason to pop the cover at this point. Not that fresh lube would hurt anything.
I suggest that it's probably your original axle. If you like the gearing, then order yourself a conversion style locker for it. Then when that arrives, you'll have good reason to pop the cover and change the lube while you're exchanging the spiders for the locker.
Posi's wear out, they don't suddenly start working.
Old Mar 31, 2010 | 07:00 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: I have posi?
Hey there is a 99 percent chance that you dont have posi , but the good news is that you either have a 323 or more than likely a 342 gear ratio in that car! You lucky dog.
Old Mar 31, 2010 | 07:02 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: I have posi?
I actually like my open rear but i wish it was a v6 rear. As they are both the same exact car. The v6 came with a more disirable ratio though. I like my open rear cause the one to two shift really kicks the car out sideways with an auto trans.LOL
Old Mar 31, 2010 | 07:05 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: I have posi?
https://www.thirdgen.org/1985-pontiac-firebird
Old Mar 31, 2010 | 07:34 PM
greatskiiiier's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
Axle/Gears: 12 bolt/ 4.11
Re: I have posi?
if you had 1 wheel spin before then you dont have posi, even with an open diff you can spin both tires if they both have equal traction, so now that youre making more power, youre giving both tires enough power to spin,
enjoy the new found fun!
Old Mar 31, 2010 | 10:45 PM
Re: I have posi?
Been a little while since I sold trucks, the open differential is different than a setup like the Eaton G80 locking differential right? Open is where the power goes to the wheel with the least resistance if I remember right, correct?
Seems like I probably do have the 3.42 differential which is good for the 305 it's paired with. I will get the lube changed after I'm done getting the car ready for inspection...I still have a little ways to go. I tried the spinning one wheel thing before and came out with some weird ratio that doesn't exist, I forgot what it was.
KO1
16
Oct 15, 2015 05:00 PM
92projectcamaro
Sep 29, 2015 07:07 PM
