Camshaft Perfection
Old Apr 1, 2010 | 12:11 AM
thomas707's Avatar
Car: 1989 RS Camaro
Transmission: TH700R
Axle/Gears: No posi YET!
Camshaft Perfection
alright i want my 1989 305 tbi auto to sound beefier will this camshaft fit and will there be any damage to my engine if it does fit an i put it in.
http://www.summitracing.com/parts/CC...e%7c5.0L%2f305
Old Apr 1, 2010 | 03:05 AM
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
Re: Camshaft Perfection
Your stock valve springs are not rated for that lift.
Also, your guides may need to be turned down to accomodate the increased travel, though I'm not 100% on whether or not thatwill be necessary.
Old Apr 1, 2010 | 04:30 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Yes damage, it is not the right cam for your LO3, it is flat tapped, it has too much lift and duration.
You need a hydraulic roller cam (wich is better). LT1/LT4 (not hot) cam is already plenty for your 187 heads. https://www.thirdgen.org/forums/tbi/...-ultimate.html
For the sound you need to look for an aftermarket exhaust, the cam is not going to change it much.
Old Apr 1, 2010 | 08:27 PM
greatskiiiier's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
Axle/Gears: 12 bolt/ 4.11
i agree with everything stated, although a cam will change sound, but for what you want id just get an exhaust
Old Apr 1, 2010 | 09:29 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
the tune will need to change.
Old Apr 2, 2010 | 06:49 AM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Oh, NO! That cam is MUCH TOO BIG for your engine. Also, it's a decades old 30+30 design, hence nostalgia. Barely idle, no brakes, forget emissions, virtually no low end, power won't come on until way up the band.
Awful choice, you'd hate it.
Jake
Old Apr 2, 2010 | 01:54 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Start with the exhaust, leave the cam alone for now. You'll never get a racey, lopey idle with the TBI system anyway. Besides, sound doesn't really matter. Only acceleration matters. You'll look awfully dumb if you drive a car that sounds fast but loses every race to every Honda. Better to sound stock but be able to slay Vipers.
Old Apr 3, 2010 | 08:45 AM
Car: 98 z28
Engine: ls1
Transmission: t56
everyone has a different opinion on what they want, speed doesnt matter to everyone so dont push your ideals onto them
but in all seriousness, i agree with atilla, your car isnt going to sound good until you have an exhaust, and if you do the exhaust right youll be happy with the sound
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
meeklay812
Oct 1, 2015 03:46 PM
