New Engine Thoughts
Old Apr 5, 2010 | 03:56 PM
megtom2's Avatar
Car: 1989 Pontiac Formula 350
Engine: 350 tpi
Transmission: 700
New Engine Thoughts
My 1989 Formula 350 engine is about to be toast. I can purchase a L31 vortec engine outof a 99 Suburban that the bottom end needs a little work for a couple hundred bucks.
I also can purchase a vortec/tpi intake and a ZZ4 cam.
My questions are if I will need to get the 062 cast heads worked on to work with the ZZ4 cam or would I be better off keeping them as is and reusing my L98 cam?
Also with my setup being a MAF car would I need a prom change with the change of a cam? Would the present prom be fine with just the vortec heads?
Forgot to point out I plan on keeping the TPI in all scenarios.
Old Apr 5, 2010 | 08:03 PM
Pocket's Avatar
Car: 91 Trans Am
Re: New Engine Thoughts
Use your L98 heads and cam then its a direct swap. Compression is comparable and the internals are updated
CarGuyDennis
137
Dec 6, 2016 11:02 PM
TheExaminer
Aug 26, 2015 04:59 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
