Oil loss? 1/2 quart in a month?!
Old Apr 6, 2010 | 05:31 AM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Hey guys, My car has 171000 km on it, I use Mobile 1 10w30 (I get a discount so it's dirt cheap) I have noticed this year, really badly my valve seals leak when I first fire it up.. Could they be leaking all the time causing this mass of oil to be lost?
Old Apr 6, 2010 | 09:16 AM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
Re: Oil loss? 1/2 quart in a month?!
How many miles did you drive? According to GM using a quart every 700-1000 miles is "normal". Yes bad valve seals will cause oil consumption. You could change the valve seals and it will help for a while but most likely the valve guides are worn and you probably need to rebuild the heads. Some thicker oil would slow the consumption down some.
If your valve seals leak when you start it up 1/2 a quart is normal.
Old Apr 6, 2010 | 09:45 AM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
Don't use thicker oil. It treats the symptom and makes the problem worse.
If you think the problem is the valve seals, replace them and see if it helps. If you don't wanna rip the head apart, just keep your oil level at the correct level.
Old Apr 6, 2010 | 10:12 AM
Kevman's Avatar
Engine: 2004 LQ4
I was going to change to Vortec 059 heads, I have a set, just waiting for a TPI intake, and wiring harness..
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
andy74
Sep 3, 2015 08:41 AM
RyanJB
Sep 2, 2015 01:27 PM
