Speedometer Cable - What Length??
Old Apr 6, 2010 | 06:33 PM
camarobuff1's Avatar
Car: 1992 Z28 Z03
Transmission: AT
Axle/Gears: 3:73
Hey, my Speedo Cable needs replaced (speedometer not working). When looking at new ones, there are different lengths available. How do I determine which length I need, without pulling the old one first?
Also, does the speedo cable also work the tach (it's not working either)?
'88 Camaro IROC with 305 TPI.
Thanks!
-Camarobuff1
Old Apr 6, 2010 | 06:36 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Speedometer Cable - What Length??
Sorry, the speedo cable has nothing to do with the tach. As for ordering a cable, you can simplify this. Just log on to www.rockauto.com and search your application. It'll be about $5. Seriously.
Old Apr 7, 2010 | 12:53 AM
tekkitan's Avatar
Car: 87 IROC-Z
If you can find one longer than stock length, I'd recommend getting it. The stock length *JUST* fits if you run it along the same route the old one was at. Taking the old one out you may notice that it is two pieces connected together. The new one (at least the one I received) is only one piece.
This is the one I got, 80" in length.
http://www.autozone.com/autozone/cat...&parentId=12-0
Old Apr 7, 2010 | 07:03 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
It's possible that the cable itself is fine and that there are other problems. Check the following link for possible problems and fixes:
https://www.thirdgen.org/forums/inte...eedo-woes.html
JamesC
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
