Code 53 No Crank issue.
Car: 1991 RS/B4C clone
Engine: 355 TPI
Transmission: Probuilt Street/Strip 700r4
Axle/Gears: 7.625 axle with 3.23 gears/TrueTrac
Hey guys, I'm at my wits end with this damn car. Last year it started having intermittent starting issues, sometimes it would take 3 turns of the key to get it started. Then, after doing that every few months it finally left me stranded at work.
Suspecting VATS, and ruling out the starter and other components, I replaced the ignition switch. It worked for about 2 months and it started having intermittent starting issues again. Well, it left me stranded at work AGAIN.
I figured THIS TIME it had to be the starter, so I replaced it today, and it still won't start. It still gives me a code 53 when I try to start it.
I'm at my wits end. The ignition switch is new, the key is new, the connection under the dash is secure, what on earth could it be? This is my only car and it's becoming a hugely unreliable. Any suggestion on what this could be and where I could obtain the parts to fix it?
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: Code 53 No Crank issue.
let's clear something up since I don't know your level of knowledge...now when you say ignition switch, you're talking about the one that is on the steering column under the dash? or are you talking about the switch where you stick the key in?
Engine: 355 TPI
Sorry, I meant the ignition lock.
Engine: 5.1 4bbl
it could be your ignition switch on your steering column... try tilting your steering wheel up and down to different levels see if that does anything...
Engine: 5.1 4bbl
Engine: 355 TPI
Isn't code 53 VATS for TBI cars?
BumpaD82
Feb 26, 2016 02:57 PM
