Making Expositions at The Carb...
Old Apr 9, 2010 | 09:53 PM
83C_CamAroZ28's Avatar
Car: 1983 Z-28
Engine: 5.7 L
ok so i just changed my distributor cap and spark plug cables...it struggles to turn on now...:/...i have to spray so carb cleaner in the carb to get it started..if i hit the gas pedal it will turn off...i turn it on again and it starts up again with no trouble....i let it run for a lil bit but when i give it gas again it does lil explosions but it stays on so they i give it gas and it does the same thing if i rev it up high it wont do that...it will only do that when its idle-ling...
does it mean the carb needs a rebuild?...
or
wat?...
help plz...
Old Apr 9, 2010 | 10:28 PM
Fuzzman17's Avatar
Car: 92RS
Engine: 305 TBI
Transmission: 700
Re: Making Expositions at The Carb...
Always check the basics first.
Check your cap and wires. Sounds like a timing issue.
Make sure the cap was installed correctly and the the firing order is right for the wires.
I once mistakenly wired an HEI distributor like you would a points distributor. (wires all moved clockwise 1 terminal from where they should be.) ran sorta like what yours is.
Old Apr 9, 2010 | 10:41 PM
Car: 1983 Z-28
Engine: 5.7 L
o ok...yea thats my guess also bcuz its overheating also...:/...i wired the cables as shown in a camaros repairs book...does a cap a way it should b mounted on?...
Bubbajones_ya
Aug 31, 2015 12:02 PM
lt1z350
Aug 28, 2015 05:57 AM
86White_T/A305
Aug 17, 2015 12:16 AM
mustangman65_79
Aug 11, 2015 03:17 PM
z28addict8490
Aug 7, 2015 08:48 PM
