Can't find a flywheel for my application
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I am having trouble finding a flywheel for my motor build. It is a 86 up, 1 piece rear main seal, 153 tooth, internal balance flywheel. I can't find one that anybody sells. Has anybody out there had to purchase one of these? If so where did you get it?
Car: 83 camaro berlinetta
Engine: 40 over 350
Transmission: 86 T5
Re: Can't find a flywheel for my application
Isn't that like a faily comon flywheel? I don't remember at the moment, but is 153 tooth the stock size? if it is, I've seen them at Jegs, summit, and I'm sure other places, not to mention all the yards that might have one.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Car: 85 Iroc-Z
I still can not find one. The only ones that I can find are 153 tooth internal balance with a 2 piece rear main seal and a 153 tooth external balance with a 1 piece rear main seal. Neither will work though, I need a 153 tooth, internal, 1 piece rms.
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
What makes you think you need an internal balance flywheel???
Is this for a stock replacement, on a stock motor????
I found your other post, now I know why you are looking for the flywheel.............I would suggest that you "search the net" and contact one of the companies that market these kits, and ask them on their tech line, what they would recommend!!
Doesn't hurt to ask!!
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
If you really believe you need a true neutral balance 1 pcs flywheel then buy a 1 pce seal one to suit your engine and get it zero balanced
Engine: 40 over 350
Transmission: 86 T5
I don't get it. A stock flywheel, like the one I just looked up on Rock auto for a 88 Camaro is one pices seal, and nuetral balanced. Am I missing something here. All 305 and 350's are internally balanced - right? The only external balance is 383-400.
Transmission: 4L80E/4L80E
It's a problem with convention. Some consider the one-piece RMS flywheels to be "external" balance because they aren't "neutral" balanced. Others refer to them properly as "internal balance" because the damper on the front of the engine is neutral balanced.
Just buy it for 305/350 one-piece rear main seal and you'll be fine.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Stangski09
Nov 14, 2015 01:27 PM
The following site carries them:
