Header Gaskets or something else?
Old Apr 9, 2010 | 11:54 PM
will_b72's Avatar
Car: 1988 IROC Z28
Engine: 305 TBI
I went out and bought a new set of header gaskets. I was told that byson gaskets were the best and they were fairly inexpensive and so far they seem to be holding up good so far. But after I installed them there was a severe loss in power and now my car backfires under acceleration sometimes. I checked the plugs and # 2,4 and 7 are white but #1,3,and 5 are black and sooty and #6 and 8 are wet and smell like fuel. I already checked the connections and they are all tight and there are no engine codes popping up. Do you think it has something to do with the new gaskets or something bigger? The car ran fine before and the only problem I had was the header bolts loosening up.
Old Apr 10, 2010 | 01:19 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Header Gaskets or something else?
it seems like one injector is over fueling. could you have crossed a spark plug wire?
Old Apr 10, 2010 | 03:52 PM
will_b72's Avatar
Car: 1988 IROC Z28
Engine: 305 TBI
Yes i found that this morning. I had crossed the # 6 and 8 wires. Thank you
z 28 jari
Sep 14, 2021 10:03 PM
Chad Speier
Sep 24, 2015 12:32 PM
bamaboy0323
Sep 12, 2015 07:14 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
