engine cuts off when stopped???
Old Apr 11, 2010 | 11:58 AM
MusclecarMania's Avatar
Hi, i have a question i cant find an answer to, please help.
im looking to buy a 92 camaro RS 25th anniversary ed., all good, needs some cosmetic repairs and such, but one thing has me worried. the engine cuts off. the car is, according to carfax, originally a TBI 305 V8, buut, the actual car has a TPI manifold, i suppose it has injection. so, the problem is the guy selling it say it runs smooth while moving, but i you stop, the engine usually will cut off. also while looking, i revved the engine at the intake manifold lightly, and the rpm's dropped, it sounded like it wanted to cut off, and i tried again and it died. uh oh. but earlier, the owner and i both revved the car smoothly. what could be the cause of this?? this is make or break for the sale. also, while starting the car, it must be kept at slightly higher than idle for around a minute or it will cut off. the owner says its probably a fuel line hole/leak or a leak in the fule injector seal. any ideas on the costs to repair/difficulty? what else could be wrong and the price to fix? anyone else have this problem? thanks for any help guys, i looking to own my first third gen camaro!!
Old Apr 11, 2010 | 01:56 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: engine cuts off when stopped???
To me this suggests either a vacuum leak somewhere (likely related to the brake booster) or possibly a low fuel pressure condition. I'd say the vacuum leak is more likely though.
Old Apr 11, 2010 | 07:20 PM
yea thats what ive come to think, because one of the previous owners obviously switched from TBI to TPI, so maybe a manifold gasket is bad or a leak in a hose.
Old Apr 11, 2010 | 09:34 PM
Air_Adam's Avatar
Is it only when actually stopping, or just using/holding/pumping the brake pedal? If its whenever you are using the brake pedal, I would be looking at the brake booster.
Old Apr 11, 2010 | 09:50 PM
According to the owner, after stopping and beginning to idle.
Reddeath210
Oct 6, 2015 08:20 AM
Wade787b
Sep 29, 2015 01:15 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
