Oil leak
Old Apr 13, 2010 | 06:35 PM
smoothjazz's Avatar
Oil leak
I have a 305 engine in my 83 Z-28.Last summer, I replaced my valve cover gaskets with new ones.Lately I am starting to smell burnt oil coming from my valve cover again.I check all the bolts that hold it down, and they are all tight.Valve covers going bad that fast?
Old Apr 13, 2010 | 08:10 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Oil leak
you didn't mention using the spreader bars. Aren't you using them?
Old Apr 14, 2010 | 04:00 AM
smoothjazz's Avatar
Re: Oil leak
Yes, they are in place also.
Old Apr 14, 2010 | 11:15 AM
HF_monster's Avatar
Car: 86' z28 (died 5/1/11) 76 k10 pickup
Transmission: th350
Axle/Gears: 3.73 open
Re: Oil leak
Id check and make sure the valve covers are not warped and if you used cork gaskets they dont tend to last long rubber coated ones seal up pretty good
Old Apr 14, 2010 | 05:36 PM
smoothjazz's Avatar
Re: Oil leak
The ones on their now are rubber.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
bamaboy0323
Sep 12, 2015 07:14 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
