Will hotcam work in stock 305
Old Apr 14, 2010 | 08:14 AM
rob88roc's Avatar
Can anyone tell me if a hotcam will work in a 1988 stock 305 IROC, 5 speed? Looking for a more lopey idle. Any other cam suggestions for this stock setup?
Old Apr 14, 2010 | 08:46 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Will hotcam work in stock 305
while that cam would give you a lopey idle, and would pass a tailpipe sniffer with a custom tune, and is cheaper than most roller cams, it's wrong for the combo you have. And any cam that gives you a lopey idle is going to require a custom tune.
You'd be much better off calling COMP and ordering an 08-000-8, 3051/3051-110. Install it on a 106 degree intake centerline.
This would drive and sound just like the SBF E303 cam, with a more reasonable 0.480" lift. Same idle quality as the hot cam, same lope, but better matched to your combo.
And since you want sound, do a Flowmaster American thunder cat-back, and do some headers. On the intake side, at least get an air foil for the TB.
Old Apr 14, 2010 | 06:20 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
how lopey? like this?
http://www.youtube.com/watch?v=nGTLJ9nS2aI
This is a Crane Cams Power Max 2050 camshaft .454/.484 with 1.5 rockers iirc.
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
marcusaw
Aug 10, 2015 08:13 AM
Leggman1
Aug 6, 2015 04:15 AM
