ever break spark plug during changing
Old Apr 14, 2010 | 08:29 PM
joekaz1070's Avatar
Car: 1987 Trans am
Axle/Gears: GM 10 bolt
Im worried about breaking a plug and not getting it out.
should I worry or don't sweat it. Any advice
Old Apr 14, 2010 | 09:41 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: ever break spark plug during changing
i have broken the ceramic on many in my lifetime ( damn i'm old ) . if you'r changing them , no sweat . if you'r going to clean , re-gap , test & re-install . o.k. thats different , today most just re-place . if plugs are covered with dirt , clean , spray with wd-40 or what ever . i normally clean/spray them down a day or two before changing & then before i try to remove . install new plugs with care not to crack ceramic . has worked for me all these years . good luck .
Old Apr 14, 2010 | 11:43 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Hello joekaz1070!!
Once you get them out, don't crank the crap out of them putting them in either (use the proper torque value, 22 ft lbs), makes it easier to get them out the next time!!
Use a "little" bit of anti-seize on them too!!
eightsixseven
Dec 16, 2024 01:50 PM
apo_bailon15
Mar 28, 2016 05:20 AM
evilstuie
Feb 28, 2016 03:33 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
