How to set valve spring load?
Old Apr 16, 2010 | 12:24 PM
ranger77's Avatar
Car: 82 firebird
Transmission: i believe 200c
Axle/Gears: 3.43 Posi
I just got a camshaft kit with springs that say i have to set the load at 105 lbs @ 1.700" Does anyone know how to do this? i havent worked on cars since the 70's and i nvr did this.
Old Apr 16, 2010 | 01:22 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: How to set valve spring load?
you need to measure installed height with a gauge and measure spring pressure with a special tool. its easier to take them to a good machine shop that does performance work and has all the proper tools.
Old Apr 16, 2010 | 06:21 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Seat pressure is only one part of having the valve springs set up properly. If the cam lift is too great, the springs can bind or the bottom the the retainers can contact the top of the valve guide/seal. Unless you have the special tools, having the heads set up by a machine shop is the best way to do it.
customblackbird
Aug 15, 2021 10:16 PM
gta90
Sep 15, 2015 04:00 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
89mulletbird
Aug 12, 2015 07:08 PM
